If you are trying to fill your garage with rare hypercars, exclusive festival rewards, or just millions of Credits in Forza Horizon 6, you already know that regular racing takes too long. The fastest shortcut to wealth in the game has always been farming Super Wheelspins through the Car Mastery system.
The strategy is simple: you buy specific cars, grind out Skill Points using optimized custom maps or drift zones, and then spend those points in the Car Mastery menu to unlock the "Spinball Wizard" perk for instant rewards. However, not every vehicle is built equal. To maximize your hourly returns, you need a highly efficient setup.
Here is a breakdown of the best cars in Forza Horizon 6 for farming Skill Points and turning them into rare rewards.
1. The Skill Point King: 1998 Subaru Impreza 22B-STI
If you ask the Forza community what the absolute "meta" car is for building a Skill Point bank, the 1998 Subaru Impreza 22B-STI is the unanimous answer.
The Multiplier Advantage: When fully upgraded through its Car Mastery tree, the Subaru 22B unlocks a massive 9.0x Skill Multiplier (compared to the standard 5.0x or 6.0x on regular cars).
The 500,000 Point Cap: In FH6, a single skill chain caps out at 10 Skill Points, which requires a total score of 500,000 points. Because of the 22B's 9.0x multiplier, you only need a base score of roughly 55,600 points before banking to hit that 10-point max.
How to execute the farm:
Grab a 22B from the Autoshow or Auction House.
Head to the Creative Hub, open EventLab, and look for custom "Skill Point Estate" or time-attack blueprints designed with dense rows of smashable props (like bowling pins, solar panels, or ramps).
Using the 22B, a single 20-to-24-second pass through these prop-heavy tracks will net you a clean 60,000 base score.
Once the multiplier hits 9.0x, stop, let the 10 Skill Points register, and hit restart. You can easily clear 600 Skill Points per hour using this method.
2. The Conversion Cars: Turning Points into Spins
Once you have accumulated hundreds of Skill Points, you need to dump them into cars that offer direct Super Wheelspin rewards.
Option A: The Budget Method (Subaru 22B Double-Dip)
The beautiful thing about the Subaru 22B is that it isn’t just great for earning points; it is also one of the cheapest paths to spending them.
The Cost: You can buy additional copies of the 22B cheaply.
The Path: Open the Car Mastery tree. If you path intelligently—going slightly to the right first to grab cheaper nodes before heading straight up—you can unlock the Super Wheelspin perk for just 30 Skill Points total.
The Math: With a 600 Skill Point bank earned from your EventLab grinding, you can buy and unlock 20 individual Subarus, yielding 20 Super Wheelspins in a single sitting.
Option B: The High-Roller Method (2024 Lamborghini Revuelto)
If you have extra in-game Credits to spare and want a dense concentration of rewards without buying dozens of cheap cars, look to the Lamborghini Revuelto.
The Cost: It requires a larger upfront Credit investment.
The Path: It takes 39 Skill Points to max out its relevant mastery nodes.
The Reward: The Revuelto’s tree is packed. Instead of just a single spin, it features a mix of both regular Wheelspins and Super Wheelspins (including the Spinball Wizard node). It is a heavier point investment, but it cleans out your point bank faster and offers multiple prize drops per car.
The Ultimate Progression Shortcut
The grind-and-convert loop is incredibly reliable, but it still requires a significant time investment to sit through EventLab loading screens and manually click through dozens of Car Mastery menus. For players who want to skip the repetitive prop-smashing entirely and get straight to the high-tier rewards, using external service platforms is a popular alternative. On verified platforms like U4N, you can bypass the tedious hours of grinding by opting to buy FH6 super wheelspin cheap packages. This safely loads your account with hundreds of spins instantly, letting you pull rare Horizon Edition cars and millions of Credits without spending your weekend running the same 20-second track over and over.
Summary Table: Farming Efficiency Breakdown
Car Primary Role Point/Skill Investment What Makes It Special
Subaru Impreza 22B-STI Point Farming Requires full mastery tree setup Unlocks a 9.0x multiplier; hits the 10-point cap in under 25 seconds on custom maps.
Subaru Impreza 22B-STI Spin Conversion 30 Skill Points (Optimized path) Extremely cheap to buy in bulk; gives 1 Super Wheelspin per car.
Lamborghini Revuelto Spin Conversion 39 Skill Points High upfront cost, but bundles regular and Super Wheelspins in a single tree.
Aston Martin Vulcan Alternative Farmer High S2-class mastery setup Exceptional handling and speed multipliers for open-world or highway skill chains.
Pro Tip: Keep an eye on the Auction House for "pre-owned" cars. If you are buying cars strictly to farm their Mastery Trees, make sure you aren't accidentally buying a used car that a previous player has already cleared out. Stick to the Autoshow for guaranteed fresh, un-popped mastery trees!
