Where to Find the Shaker in Arc Raiders
Messaggioda ShadowSeeker » 13/02/2026, 4:15
What Exactly Is the Shaker?
Before jumping into where to find the Shaker, it’s helpful to understand what it does. When you hold down the fire button while using the Shaker, it plays a rhythm—either a repeating beat or a sequence of sounds. This interaction disables your ability to use weapons, breach doors, or loot containers unless you unequip the gadget. This makes it a gadget best used in the right situations, particularly when you're not in immediate combat.
Where Can I Find the Shaker?
The Shaker is primarily found in the Residential areas in Arc Raiders. Here’s a breakdown of its sources:
Buried City (Music Puzzle Room) – This is one of the most common locations where you can obtain a Shaker. You’ll need to explore the city’s puzzle rooms to find it. These are hidden and often require solving some environmental challenges to access them.
Goalie Deck – Another location where Shakers may appear is the Goalie Deck, typically a high-risk, high-reward area. Expect some tough opposition, but with patience, the Shaker is a reliable find here.
Scavenging – If you’re actively scavenging or looting through various environments, there’s always a chance to stumble across a Shaker. This can happen during your regular exploration, especially in less-traveled zones. Keep your eyes peeled for boxes or containers that might hold it.
How to Repair the Shaker
Once you’ve got your hands on a Shaker, you might find yourself needing to repair it after a few uses. Repairing the Shaker isn’t too difficult but does require some resources. Here's what you’ll need:
4 Plastic Parts
These parts are relatively common, so you shouldn't have too much trouble collecting them. Simply scavenge for them in various areas or dismantle items you no longer need.
The repair process will restore +50 durability, so you can keep using the Shaker without it breaking down on you too soon.
Can I Recycle or Salvage the Shaker?
Yes, the Shaker can also be recycled or salvaged for parts. Here’s what you’ll get from each:
Recycling: If you choose to recycle the Shaker, you’ll get 10 Plastic Parts in return.
Salvaging: If you salvage the Shaker, you’ll receive 4 Plastic Parts.
These options are useful if you no longer need the Shaker but want to make use of its materials.
How to Use the Shaker in Combat and Exploration
While the Shaker doesn’t have any direct combat effects, it can still be useful in certain situations. For example:
Attracting ARC's Attention: The main purpose of the Shaker is to make noise, which will draw ARC to your location. This can be useful if you want to lead enemies to a specific area or confuse them during a battle.
Impressing Other Raiders: Let’s face it: using a Shaker is just fun. You can show it off to your teammates or other players, especially if you’re in a social situation like a group raid. It’s a nice gadget for building some team spirit.
However, remember that while you're using the Shaker, you won’t be able to fire weapons or interact with other things like containers, so use it wisely. It's best to save it for when you’re not in a rush or are confident the area is safe.
Should I Buy the Shaker or Find It?
While it’s definitely more satisfying to find the Shaker through scavenging or by completing specific puzzles, if you’re in a rush, you might want to buy Anvil blueprint to get the Shaker right away. The Anvil blueprint can be purchased, which will give you direct access to the Shaker gadget, cutting down on time spent searching. Whether you’re in a hurry or just want to be sure you have one for your next mission, this can be a viable option.
Finding the Shaker in Arc Raiders isn’t overly complicated, but it does require some patience. Focus on exploring the Residential areas, solving puzzles in the Buried City, and scavenging in various places to increase your chances of stumbling upon one. Once you’ve got it, it’s all about having fun with its rhythmic effects—just remember it comes with some limitations on what else you can do while using it.
If you need to replace or repair your Shaker, the materials required are minimal and easy to gather, and if you want to recycle or salvage it, you’ll get back valuable parts like Plastic Parts. All in all, the Shaker is a fun gadget to add to your collection, but it’s one you’ll need to use at the right time to make the most of it.
Flickering Flames Phase 5 Meals | All Platform
ShadowSeeker
