Arc Raiders: Light Shield vs. Medium Shield – Which One Shou
Messaggioda ShadowSeeker » 05/02/2026, 8:25
What Are the Main Differences Between the Light Shield and Medium Shield?
The most significant differences between the Light and Medium Shields are their damage mitigation and mobility penalties. Let’s take a look at each.
Light Shield
The Light Shield offers 40% damage mitigation, which means it can absorb 40% of incoming damage before it affects your health. Additionally, it has no movement penalty, allowing you to maintain full mobility while using it. This makes it ideal for players who prefer agility over heavy defense.
Medium Shield
On the other hand, the Medium Shield provides 60% damage mitigation, offering better protection against damage. However, this comes at a cost: it has a slight movement penalty. You'll be able to move around, but not at the same speed as when you’re using the Light Shield.
In practice, this means the Light Shield is better for players who rely on fast movement and dodging to stay alive, while the Medium Shield offers more protection but at the expense of some agility.
How Do They Compare in Terms of Durability?
When it comes to durability, both shields are relatively similar, but they are still different in key areas. The Light Shield can be repaired with 4 Plastic Parts, which is fairly inexpensive, while the Medium Shield requires a bit more material to repair.
If you're looking to save resources and still get a good level of protection, the Light Shield might be the better option for you.
Which Shield Is Better for Solo Play?
In solo play, the Light Shield often stands out. The mobility it provides is invaluable when facing off against enemies in a fast-paced environment. You'll be able to keep your distance and dodge attacks more effectively, allowing you to outmaneuver enemies and manage your health more efficiently. The 40% damage mitigation is usually sufficient for most solo encounters, especially if you play smart and keep your distance.
However, if you prefer a more tanky playstyle and don’t mind moving slower, the Medium Shield can be a solid choice. The 60% damage mitigation is great for taking on tougher enemies, especially when you're up against higher-level threats that deal significant damage.
Which Shield Is Better for Team Play?
In team play, the Light Shield tends to be favored more. The ability to move around quickly is essential in multiplayer scenarios, where positioning and the ability to dodge enemy fire are critical to survival. Having a teammate with a Light Shield can provide mobility, allowing your team to outflank enemies or get into advantageous positions more effectively.
The Medium Shield, however, can be an excellent choice for players who take on a more defensive role in a team. If your team needs someone to hold the line or absorb a lot of damage, the 60% damage mitigation makes the Medium Shield a reliable option for surviving in tougher firefights.
What About Crafting and Resources?
Both shields are fairly easy to craft, but they do require different materials. To craft a Light Shield, you’ll need:
2x ARC Alloy
4x Plastic Parts
This crafting recipe is simple and won’t take much time or effort to gather resources, which is why the Light Shield is often a go-to choice early in the game. If you’re looking to buy arc raiders bobcat blueprint, keep in mind that it can give you some extra flexibility when building out your loadout, but gathering the necessary components for these shields is usually more than enough for most encounters.
The Medium Shield, while slightly more powerful, requires more crafting materials, so it's a bit of a trade-off when it comes to efficiency.
Which Shield Is More Cost-Effective?
If you’re running low on materials or playing in a way that requires frequent repairs, the Light Shield is likely your best bet. It uses fewer resources for crafting and repairing, and its effectiveness for fast-paced movement means you won’t get hit as often, ultimately saving you more on repairs and consumables.
The Medium Shield, while more durable in terms of damage mitigation, has higher repair costs. Additionally, since you move slower, you may be more likely to take damage in the first place, making it slightly less cost-effective overall.
Should You Use Light or Medium Shield in the Long Run?
In the long run, the choice between the Light and Medium Shield often comes down to your playstyle and the kind of missions you're tackling. If you’re just starting out or frequently find yourself in fast-paced scenarios, the Light Shield is your best option. It's great for mobility and won’t weigh you down. Plus, it offers just enough damage mitigation to get you through most regular encounters without overburdening you with a movement penalty.
However, as you face more challenging enemies and scenarios, the Medium Shield could become more valuable. The increased damage mitigation might make the difference between life and death, especially in situations where you can’t rely solely on dodging or quick positioning.
Light Shield or Medium Shield?
The decision between the Light Shield and Medium Shield ultimately depends on your preferred playstyle and the type of encounter you're facing. If you value speed and agility, the Light Shield will serve you well in most cases. On the other hand, if you find yourself taking too much damage and need more protection, the Medium Shield is a better fit, provided you don’t mind the slight loss of mobility.
For most players, especially those in the early stages of the game, the Light Shield is a great choice because it balances mobility and defense without excessive resource investment. But for those who want to push through tougher areas or need to tank more damage, the Medium Shield will be your shield of choice.
Light Gun Parts Blueprint | All Platform
ShadowSeeker
