Arc Raiders Angled Grip II Blueprint: A Comprehensive Guide
Messaggioda EchoFlux36 » 19/01/2026, 2:32
If you’re looking to upgrade your weapons in Arc Raiders, the Angled Grip II is one of the essential underbarrel mods you’ll want to get your hands on. It’s an uncommon mod that can help you reduce horizontal recoil, improving your accuracy during combat. Whether you’re crafting or scavenging, here’s everything you need to know about the Angled Grip II Blueprint.
What is the Angled Grip II?
The Angled Grip II is a weapon mod that significantly reduces the horizontal recoil of your weapon, making it easier to land shots accurately, especially during sustained fire. This is particularly useful when you're using weapons with high recoil or when you need to maintain accuracy in intense combat situations.
Mod Type: Underbarrel Mod
Rarity: Uncommon
Effect: 30% Reduced Horizontal Recoil
This mod is compatible with a variety of weapons in Arc Raiders, including the Ferro, Kettle, Rattler, Stitcher, and several others. Its functionality is simple but effective—if you're aiming for greater control over your shots, this mod is a game-changer.
How to Get the Angled Grip II Blueprint
The Angled Grip II Blueprint is not something you can simply pick up from vendors. It is locked and must be obtained through specific means in the game. Here’s how you can get your hands on it:
Sources
Scavenging: The Angled Grip II Blueprint can be found by scavenging in various locations across the map. Keep an eye on your surroundings and make sure you thoroughly check high-loot areas.
Crafting: If you want to craft the Angled Grip II, you will need to obtain the blueprint first. Once you have the blueprint, you can craft it using specific ingredients.
Blueprint Locations
The blueprint for the Angled Grip II can be found in the following locations:
Residential Drawer
Residential Desk Drawer
Residential Closet
Residential Cabinet
These areas are scattered throughout the game world, so it’s crucial to explore every nook and cranny in residential zones to uncover these valuable blueprints.
Crafting the Angled Grip II
Once you have the Angled Grip II Blueprint, you’ll need the following ingredients to craft it:
2x Mechanical Components
3x Duct Tape
You also need to have Gunsmith Level 2 to craft the Angled Grip II.
After gathering the materials and meeting the crafting requirements, you’ll be able to create one Angled Grip II per crafting session.
Recycling and Salvaging the Angled Grip II
If you find yourself in need of some extra materials or want to make space in your inventory, you can recycle or salvage the Angled Grip II.
Recycling Results:
1x Mechanical Components
1x Duct Tape
Salvaging Results:
This is a great option if you’ve crafted or acquired more Angled Grip IIs than you need.
How Does the Angled Grip II Improve Gameplay?
The primary advantage of the Angled Grip II is its ability to reduce horizontal recoil. If you’re facing tough enemies in long-range combat or dealing with recoil-heavy weapons, the mod becomes an invaluable asset. It allows you to:
Stay on target during sustained fire.
Increase accuracy with weapons prone to recoil.
Improve control in chaotic firefights, especially when you’re under pressure.
In practice, players often struggle with weapons that kick too much, making it difficult to land shots consistently. The Angled Grip II helps mitigate this problem, making it easier to control your weapon, especially in medium-to-long-range battles.
Where to Find Arc Raiders Blueprints for Sale
If scavenging or crafting isn't your preferred method for acquiring blueprints, there are arc raiders blueprints for sale through various in-game vendors or external marketplaces. Be sure to check the current market prices and verify the authenticity of sellers if you're purchasing through external channels.
The Angled Grip II is an excellent underbarrel mod that helps players manage recoil, making it easier to control their weapons during intense fights. Whether you're crafting it from a blueprint or scavenging in the world, it’s worth the effort to acquire. By improving horizontal recoil, it’s a reliable mod for both newcomers and veteran players looking to improve their weapon handling. Don’t forget to explore locations like Residential Drawers and Residential Cabinets for the blueprint and check out U4N for any blueprints you might want to buy and sell arc raiders blueprints safely.
Community Highlight: Arc Raiders Best Assault Rifles 2026
EchoFlux36
