Arc Raiders Weapons Guide: Managing Complex Gun Parts Effici
Messaggioda ShadowSeeker » 06/01/2026, 2:54
For players of Arc Raiders, understanding crafting materials can make a big difference in how efficiently you progress through the game. One of the key components for advanced weapons is Complex Gun Parts. In this guide, I’ll break down how these parts work, how to get them, and what you can do with them, based on how most players approach the game.
What Are Complex Gun Parts and What Are They Used For?
Complex Gun Parts are classified as Epic materials in Arc Raiders. They are mainly used for crafting advanced weapons, such as the Aphelion, Equalizer, and Jupiter.
In general, most players see these parts as a mid-to-late-game resource. They’re not something you use early on because crafting them requires other gun parts that you usually acquire after some experience with the game.
In practice:
Crafting: You need a specific blueprint to craft Complex Gun Parts, which ensures that only players who are actively progressing can make them.
Recycling: If you have extra or outdated parts, you can recycle them down into simpler gun parts, making it easier to keep your inventory useful.
Salvaging: Certain high-tier weapons can also be broken down into Complex Gun Parts, which is helpful if you want to switch gear without losing resources.
Most players treat Complex Gun Parts as a flexible material—they’re not rare enough to hoard unnecessarily, but they’re valuable enough that careful management matters.
How Do You Craft Complex Gun Parts?
Crafting these parts is straightforward, but it requires a few prerequisites:
Ingredients: 2× Light Gun Parts, 2× Medium Gun Parts, and 2× Heavy Gun Parts.
Workshop Level: Refiner 3 is required to process them.
Blueprint: You must have the Complex Gun Parts blueprint to unlock crafting.
In practice, this means that players usually gather all lower-tier gun parts first, then combine them in batches. Most players find it efficient to craft multiple parts at once since the material requirements are significant, and it saves time in the long run.
Once you have Complex Gun Parts, you can use them in higher-level weapon recipes:
Aphelion: 3× Magnetic Accelerator + 3× Complex Gun Parts + 1× Matriarch Reactor
Equalizer: 3× Magnetic Accelerator + 3× Complex Gun Parts + 1× Queen Reactor
Jupiter: 3× Magnetic Accelerator + 3× Complex Gun Parts + 1× Queen Reactor
In general, the limiting factor isn’t always the Complex Gun Parts themselves, but the reactors, which are harder to obtain and often tied to specific missions or enemy encounters.
Where Can You Find Complex Gun Parts?
Most players acquire Complex Gun Parts in one of three ways:
Security Missions: This is the most common source. You can reliably farm these parts from enemies in higher-tier security areas.
Recycling Weapons: High-level weapons like Aphelion, Equalizer, and Jupiter can be broken down to reclaim 3 Complex Gun Parts per weapon.
Buying from NPCs: Some vendors, like Celeste, sell Complex Gun Parts directly. However, prices are usually high, so this method is used mostly when players need parts immediately rather than farming them.
In practice, players tend to mix these approaches. For example, you might farm Security missions for bulk materials while salvaging leftover weapons from previous runs to keep your stock up. Some players also explore options to buy arc raiders gear, which can include parts or complete weapons, if they want to bypass part of the farming process.
How Do Recycling and Salvaging Work?
Understanding recycling and salvaging is essential for resource management in Arc Raiders.
Recycling: Complex Gun Parts can be recycled into 3 Simple Gun Parts. This is useful if you overproduce or want to convert Epic parts into more basic materials for other crafting.
Salvaging: Breaking down a high-tier weapon like Aphelion gives you 2 Simple Gun Parts, which is slightly less than recycling directly. Most players only salvage weapons if they no longer need them or want a partial refund on the investment.
The general rule among experienced players is to prioritize recycling when possible, since it gives a better return in base materials. Salvaging is mostly a fallback option.
How Should Players Manage Their Complex Gun Parts?
Inventory management is important in Arc Raiders. Complex Gun Parts weigh 1.0 unit and stack up to 3 per slot.
Stacking: Because they only stack to 3, most players try to craft or use them in batches to avoid inventory clutter.
Timing: It’s usually more efficient to gather enough lower-tier gun parts and craft Complex Gun Parts in bulk rather than producing them sporadically.
Planning: Since higher-level weapons consume 3 Complex Gun Parts per craft, it helps to plan which weapons you want to focus on first, so you don’t run out mid-crafting session.
In general, careful planning here saves a lot of time and reduces wasted runs, which is something experienced players always emphasize.
Common Mistakes New Players Make
Overstocking: Some players hoard Complex Gun Parts without crafting, which limits space for other materials.
Ignoring Recycling: Not recycling leftover parts leads to inefficiency; recycling ensures that every run provides usable resources.
Underestimating Reactors: Many players assume that only the parts matter, but the limiting factor is usually the Matriarch or Queen Reactor, not the Complex Gun Parts.
By avoiding these mistakes, you can make crafting advanced weapons smoother and less frustrating.
Complex Gun Parts are a cornerstone of advanced weapon crafting in Arc Raiders. Most players approach them as a mid-to-late-game resource and use a combination of farming, salvaging, and careful crafting to maximize efficiency. Understanding where to find them, how to craft them, and how to manage them can make a big difference in progression.
Whether you are crafting your first Aphelion or planning to upgrade multiple weapons, treating Complex Gun Parts as a flexible, reusable resource will save you time and make your gameplay more consistent.
ShadowSeeker
Erotic Service Provider
Messaggioda sarakhan69 » 12/01/2026, 6:56
These women have stunning personalities and are incredibly appealing. Every single one of our South Delhi Escort girls is a highly skilled, competent, attractive, and well-known girl. You can relive all of your old and missed days with them. It's time to schedule our beauties for sensual pleasure and give your pal a celebrity call.
sarakhan69
