Helldivers 2 Best Weapons Against Automatons Ranked
Messaggioda icyriftstorm » 09/09/2025, 8:18
Helldivers 2 continues to challenge players with waves of relentless Automatons, making weapon choice critical for survival. As someone who has spent dozens of hours testing different loadouts, I wanted to share my ranking of the best weapons to take down these mechanical foes efficiently. Whether you’re a veteran Helldiver or just starting out, this guide will help you optimize your arsenal.
1. M-4 Liberator
The M-4 Liberator remains a top-tier choice against Automatons. Its high rate of fire and solid accuracy make it ideal for both crowd control and single-target elimination. I’ve found that pairing it with explosive rounds can shred automaton armor quickly. For players looking to focus on sustained damage without constantly reloading, this weapon is unbeatable.
2. AR-12 Railgun
For precision strikes and armor-piercing damage, the AR-12 Railgun is exceptional. It excels at picking off high-priority targets from a distance, allowing you to control the battlefield more effectively. While it requires careful aiming, the payoff is huge against tougher Automatons. If you’re looking to maximize efficiency, the AR-12 is a must-have.
3. Piranha SMG
Close-quarters combat against swarms of Automatons demands something fast and reliable. The Piranha SMG fits this role perfectly, with its insane rate of fire and mobility. While it lacks the punch of heavier weapons, it compensates with sheer volume of damage. It’s especially useful when you need to move quickly between objectives or protect teammates.
4. Inferno Launcher
When dealing with clusters of Automatons, area-of-effect weapons like the Inferno Launcher shine. The fire-based damage not only melts through multiple targets at once but also keeps enemies at bay. This weapon is particularly satisfying in missions where you face waves of robots with minimal cover.
5. Rumbler Shotgun
For players who enjoy getting up close and personal, the Rumbler Shotgun delivers devastating short-range damage. It’s perfect for breaching choke points or ambushing groups of Automatons. Just be mindful of ammo management, as its heavy-hitting rounds burn through supplies quickly.
Tips for Maximizing Your Loadout
Beyond weapon choice, don’t underestimate the benefits of in-game resources. If you want to boost your arsenal or unlock some of the more advanced gear, it’s worth considering options to buy Helldivers 2 medals or look for cheap Helldivers 2 medals to enhance your progression without grinding endlessly. Efficient use of medals can make a significant difference in how quickly you can adapt to tougher automaton encounters.
In conclusion, choosing the right weapon for the job can turn a near-death experience into a flawless mission. Whether you prefer precise long-range rifles, rapid-fire SMGs, or explosive area-of-effect tools, there’s a weapon on this list to fit your playstyle. Experiment with different combinations and see which loadout helps you dominate the Automatons most effectively.
icyriftstorm
