U4N: Aion 2 Open World Farming Guide
Messaggioda CrystalViper » 27/05/2026, 3:08
Open world farming has always been one of the biggest parts of the Aion experience, and in Aion 2, it looks even more important because of the game’s larger world design, aerial movement system, and faction-based PvPvE structure.
That scale changes how farming works. Players are no longer just standing in one small grind spot for hours. Efficient farming in Aion 2 is expected to revolve around mobility, resource routing, mob density, and avoiding unnecessary PvP deaths.
This guide breaks down the best ways to approach open world farming efficiently, especially for solo and small-group players.
Why Open World Farming Matters in Aion 2
In most MMORPGs, dungeon farming eventually becomes the main source of progression. But Aion has always been different because the open world itself is valuable.
In Aion 2, open world farming is expected to provide:
Kinah income
Upgrade materials
Crafting resources
Gear enhancement items
XP progression
PvP rewards in contested zones
The PvPvE structure from the original Aion is still a core part of the franchise. That means farming locations with the best rewards will probably also carry the highest PvP risk.
A simple example:
Safe low-level zone:
2,000–3,000 Kinah per 10 minutes
Very low death risk
Contested Abyss-style zone:
5,000–8,000 Kinah per 10 minutes
Frequent enemy faction ambushes
Players who survive longer in dangerous areas usually end up progressing faster overall.
Best Farming Strategy: Rotation Over Camping
One mistake many players make in MMOs is staying in one spot too long.
In a large open world game like Aion 2, rotation farming is usually much better.
A good farming route should include:
High mob density
Fast respawn timers
Nearby gathering resources
Minimal travel downtime
Escape routes for PvP encounters
For example, if a farming loop takes 6 minutes to complete and mobs respawn in 5 minutes, you can maintain nearly constant combat uptime.
That is far more efficient than waiting for respawns in a crowded area.
Prioritize Fast Kill Speed Over Elite Farming
A common beginner trap is chasing elite monsters too early.
Let’s compare two situations:
Regular Mob Route
12 mobs per minute
500 Kinah average loot
20 seconds per fight
Estimated hourly income:
Around 360,000 Kinah
Elite Mob Farming
2 elite mobs per minute
2,500 Kinah average loot
60–70 seconds per fight
Around 300,000 Kinah
Even though elites drop better loot individually, slower kill speed often lowers total efficiency.
Unless elite enemies have exclusive drops, regular mob rotations are usually better for solo players.
Mobility Is Everything
Aion has always been famous for aerial movement, and Aion 2 is heavily promoting flight-based exploration and combat.
That directly affects farming efficiency.
Good players use vertical movement to:
Skip dangerous terrain
Escape PvP fights
Chain pull enemies faster
Reach hidden resource areas
Avoid crowded grinding spots
If you spend 15% less time traveling between pulls, your farming efficiency over a 2-hour session becomes significantly higher.
For example:
Slow route:
90 minutes active combat
30 minutes travel
Optimized route:
105 minutes active combat
15 minutes travel
That difference alone can mean:
+15% XP
+15–20% currency
More rare drops over time
Gather While You Farm
Many players ignore gathering professions early on. That is usually a mistake.
In open world MMORPG economies, crafting materials often spike in value during the first few months because:
High-level players rush crafting
Supply is limited
Most players focus only on leveling
If you gather resources during normal farming routes, your income increases without much extra effort.
A simple example:
Mob farming: 400,000 Kinah/hour
Resource gathering during route: +80,000 Kinah/hour
That is a 20% increase in profit just from smarter pathing.
This is also where player-driven economies become important. Some players focus purely on gathering and market flipping, while others combine grinding and trading. Because of that, many players also watch market prices closely or use external trading communities like U4N when they need faster progression or want to sell aion 2 kinah efficiently without wasting time on low-profit farming routes.
Avoid Overcrowded Farming Spots
The “best” farming area on YouTube is often the worst place to farm after launch week.
Why?
Because:
Too many players compete for mobs
Respawn timers become inefficient
PvP activity increases
Kill participation gets split
A slightly weaker zone with fewer players is often more profitable.
Example:
Popular Spot
10 players competing
6-second wait between pulls
Secondary Spot
2 players competing
Constant pulling
The second location usually wins in long sessions.
Small Group Farming Is Extremely Efficient
Aion has always rewarded coordinated small groups.
A balanced 3-player team can:
Pull larger packs
Farm elites faster
Defend against PvP attacks
Maintain nonstop rotations
A strong trio often farms 40–60% faster than three solo players farming separately.
Ideal small-group setup:
Tank/frontliner
AoE DPS
Support/healer
That setup minimizes downtime and potion costs.
Watch the Economy Early
The first month after launch is usually where the biggest farming profits happen.
Certain materials that sell for:
500 Kinah in Month 3
may sell for:
5,000+ Kinah during launch week
Early economies are unstable, and smart players benefit from that volatility.
Good farming players do not just look at raw drop value. They track:
Crafting demand
Enhancement material prices
Upgrade bottlenecks
Consumable shortages
Sometimes low-level materials become more profitable than high-level drops simply because everyone needs them.
Open world farming in Aion 2 will probably reward efficiency more than raw combat power. Players who understand movement, rotation timing, mob density, and market demand usually progress much faster than players who simply grind randomly.
The biggest difference between average and advanced farmers is consistency.
A player farming efficiently at:
500,000 Kinah/hour
will massively outperform someone farming inefficiently at:
300,000 Kinah/hour
Over 20 hours of gameplay, that gap becomes:
10 million vs 6 million Kinah
That difference affects gear upgrades, crafting progression, consumables, and even PvP readiness.
In a large-scale MMORPG like Aion 2, efficient open world farming is not just a side activity. It is one of the main ways players build long-term progression.
CrystalViper
Re: U4N: Aion 2 Open World Farming Guide
Messaggioda tivita4420 » 28/05/2026, 21:09
I love how this 오피사이트 makes me feel pampered and cared for.
tivita4420
Visitano il forum: Nessuno e 11 ospiti
