refractory material
refractory material
Messaggioda hyrefractory » 03/01/2026, 3:27
1. Introduction
The monoblock stopper rod is a critical flow-control refractory component used in modern continuous casting operations. Installed in the tundish, it regulates molten steel flow into the submerged entry nozzle (SEN) by precise vertical movement. Compared with traditional multi-piece stopper systems, monoblock stopper rods offer advantages such as improved structural integrity, better sealing performance, and more stable casting control.
tundish Stopper tundish Stopper
However, cracking of monoblock stopper rods remains one of the most common and serious operational problems. Cracks can lead to premature failure, unstable flow control, steel leakage, casting interruptions, and even major safety incidents. As casting speeds increase and steel cleanliness requirements become more stringent, preventing stopper rod cracking has become a key concern for steelmakers and refractory engineers.
This article provides a comprehensive analysis of why monoblock stopper rods crack and, more importantly, how to avoid cracking through proper design, material selection, manufacturing control, installation, and operation.
2. Structure and Working Conditions of a Monoblock Stopper Rod
2.1 Basic Structure
A monoblock stopper rod is typically composed of:
Rod body main structural part)
Stopper head working end contacting the SEN)
Refractory material matrix Al₂O₃–C, MgO–C, or composite)
Optional zirconia or high-purity alumina insert at the head
Steel anchoring or connecting system at the top
Unlike assembled stopper rods, the monoblock design integrates these elements into a single refractory body, which reduces joint-related failures but increases sensitivity to internal stresses.
2.2 Service Environment
During operation, the monoblock stopper rod is exposed to:
Molten steel temperatures above 1550 °C
Severe thermal gradients
Chemical attack from steel and slag
Mechanical loads from opening/closing movements
Vibrations and impact during casting
These extreme conditions make the stopper rod highly susceptible to cracking if not properly designed or handled.
3. Common Types of Cracks in Monoblock Stopper Rods
Understanding crack types helps identify preventive strategies.
3.1 Thermal Shock Cracks
Occur during rapid heating or cooling
Usually surface-initiated
Often propagate longitudinally along the rod body
3.2 Structural Stress Cracks
Caused by internal residual stresses
Often originate near material transitions or inserts
Can be invisible initially and grow during service
3.3 Mechanical Damage Cracks
Caused by improper handling, collision, or misalignment
Common near the stopper head or connection zone
3.4 Chemical Degradation-Induced Cracks
Result from oxidation of carbon
Slag or steel penetration weakens the matrix
Leads to spalling and crack propagation
4. Material Selection to Prevent Cracking
4.1 Use of Carbon-Containing Refractories
Most monoblock stopper rods use Al₂O₃–C or MgO–C materials, because carbon:
Improves thermal shock resistance
Reduces elastic modulus
Enhances crack arrest capability
However, excessive carbon can increase oxidation risk, so balance is essential.
4.2 Optimized Antioxidant System
To prevent carbon oxidation, effective antioxidants should be added, such as:
Aluminum powder
Silicon metal
Boron carbide (B₄C)
A well-designed antioxidant system reduces decarburization, which otherwise leads to embrittlement and cracking.
4.3 Functionally Graded Materials
Advanced stopper rods use graded compositions, such as:
High-purity zirconia or alumina at the stopper head
Toughened Al₂O₃–C in the rod body
High-strength refractory near the steel connection
This reduces thermal mismatch and internal stress concentration.
5. Manufacturing Factors Affecting Crack Resistance
5.1 Raw Material Quality Control
Poor-quality raw materials introduce defects that act as crack initiation sites. Strict control is required for:
Particle size distribution
Purity and impurity levels
Carbon morphology and dispersion
5.2 Homogeneous Mixing and Forming
Non-uniform mixing leads to localized stress zones. Best practices include:
High-efficiency mixing equipment
Controlled forming pressure
Avoidance of segregation during molding
5.3 Controlled Drying and Heat Treatment
Inadequate drying is a major cause of cracking. Moisture trapped inside the stopper rod can expand violently during preheating.
Key measures:
Slow, staged drying schedules
Uniform temperature distribution
Sufficient holding time at intermediate temperatures
6. Design Optimization to Reduce Cracking Risk
6.1 Geometry and Stress Distribution
Sharp corners, abrupt section changes, and sudden diameter transitions should be avoided. Smooth geometry helps:
Reduce stress concentration
Improve thermal expansion accommodation
Enhance mechanical durability
6.2 Insert Compatibility
When zirconia or alumina inserts are used at the stopper head:
Thermal expansion coefficients must be compatible
Bonding interfaces must be well engineered
Transition layers should be introduced if necessary
Poor insert design is a common cause of radial cracking.
6.3 Reinforced Neck and Connection Zones
The area near the steel connection experiences high mechanical stress. Reinforcement strategies include:
Increased material density
Fiber or whisker reinforcement
Optimized anchoring design
7. Installation Practices to Avoid Cracking
7.1 Proper Handling and Transportation
Monoblock stopper rods are large and heavy. Cracking often occurs before installation due to:
Dropping or impact
Improper lifting points
Vibration during transport
Soft padding, dedicated lifting tools, and strict handling procedures are essential.
7.2 Accurate Alignment in the Tundish
Misalignment between the stopper rod and SEN leads to uneven load and localized stress. Correct installation ensures:
Uniform contact at the stopper head
Smooth opening and closing motion
Reduced bending stress
8. Preheating and Operational Control
tundish stopper rod tundish stopper rod
8.1 Controlled Preheating
Rapid heating is one of the main causes of stopper rod cracking. Proper preheating should:
Follow a controlled temperature ramp
Avoid direct flame impingement
Ensure uniform heating of the entire rod
Temperature gradients must be minimized.
8.2 Avoiding Thermal Cycling Shock
Repeated opening, closing, and exposure to air can cause thermal fatigue. Operational best practices include:
Minimizing unnecessary stopper movements
Maintaining stable steel levels
Avoiding prolonged exposure of hot stopper rods to air
9. Chemical Protection During Casting
9.1 Slag and Steel Chemistry Control
Highly oxidizing slags accelerate refractory degradation. Control measures include:
Low FeO and MnO slag
Proper calcium treatment of steel
Stable tundish slag composition
9.2 Argon Protection
Argon purging near the stopper head can:
Reduce oxygen contact
Prevent inclusion buildup
Stabilize steel flow
This indirectly helps reduce chemical-induced cracking.
10. Inspection and Predictive Maintenance
Regular inspection helps detect early crack formation:
Visual inspection before installation
Post-casting examination
Monitoring of stopper movement resistance
Data-driven analysis of stopper rod life helps optimize future designs and operating parameters.
11. Conclusion
Cracking of monoblock stopper rods is not caused by a single factor, but by a combination of material, design, manufacturing, installation, and operational influences. Avoiding cracks requires a systematic approach covering the entire lifecycle of the stopper rod.
Key Strategies to Avoid Cracking:
Select refractory materials with high thermal shock resistance
Use optimized antioxidant systems
Apply graded and composite designs
Ensure strict manufacturing and drying control
Handle and install stopper rods correctly
Use controlled preheating and stable operating practices
Maintain proper steel and slag chemistry
By integrating these measures, steel plants can significantly extend monoblock stopper rod service life, improve casting stability, reduce downtime, and enhance overall operational safety.
LADLE SHROUD SUB ENTRY SHROUD
hyrefractory
