Proven Medal Farming Methods in Helldivers 2
Messaggioda CrystalViper » 22/11/2025, 8:38
If you’ve spent any time in Helldivers 2, you know that farming medals is one of the most satisfying ways to track your progress and unlock some of the game’s better perks. For newer players or even seasoned veterans, knowing the right strategies can make the difference between slow, tedious grinding and a smooth, efficient run. In this guide, I’ll share some Proven Methods to Farm Medals in Helldivers 2 that I’ve personally tested and refined over multiple playthroughs.
Understanding Medals and Their Importance
Before diving into the methods, it’s worth noting why medals matter. Medals in Helldivers 2 act as a measure of your performance and achievements across missions. Earning them doesn’t just feed your ego—they also unlock important upgrades and unlockables that can make your future missions easier and more rewarding. Simply put, the faster you can farm medals, the faster you can gear up and enjoy more challenging missions with confidence.
1. Focus on High-Reward Missions
One of the most straightforward Proven Methods to Farm Medals in Helldivers 2 is to prioritize missions that offer higher medal rewards. Not all missions are created equal—some smaller skirmishes may be quick, but they yield only a handful of medals. Instead, target missions that include objectives such as escorting units, completing multiple objectives, or facing large enemy waves. These missions often take a bit longer, but the medal payout per minute is significantly higher.
Tip: Keep an eye on missions marked with bonus objectives. Completing these secondary tasks often gives an extra medal boost without adding too much extra difficulty.
2. Optimize Your Loadout
Your weapon and gear choices can dramatically influence your medal farming efficiency. Choosing a loadout that balances mobility with firepower allows you to clear enemies faster and survive longer—both crucial for racking up medals. Personally, I find that pairing a reliable assault rifle with a strong area-of-effect gadget helps me handle waves of enemies efficiently while staying alive to claim more medals.
Tip: Don’t overlook support gear like turrets or supply drops. They might not get kills directly, but they improve mission survival rates, which in turn improves medal counts.
3. Play in Coordinated Teams
Helldivers 2 is inherently designed around teamwork. Playing solo can be rewarding, but you’ll likely miss out on higher medal yields that come from completing objectives efficiently with a team. Coordinated squads can tackle tougher missions faster and more safely. Communication, even through quick in-game signals, ensures that everyone covers objectives, revives teammates, and maximizes medal gains.
Pro Tip: If you don’t have friends online, try joining a consistent public squad. Familiarity with team dynamics often increases overall medal output.
4. Replay Missions Strategically
Not every mission needs to be attempted just once. Some missions are perfect for farming medals repeatedly, especially those with predictable enemy patterns and manageable objectives. These repeatable runs are at the core of many Proven Methods to Farm Medals in Helldivers 2. By sticking to a set of “golden” missions, you can streamline your farming sessions without constantly learning new enemy layouts.
Tip: Keep track of which missions consistently give the best medal-per-minute ratio and rotate them to avoid burnout.
5. Focus on Efficiency, Not Just Kills
It’s easy to get caught up in racking up kills, but medals in Helldivers 2 are often awarded for completing objectives, survival, and mission efficiency. This means that rushing and dying frequently can actually reduce your medal yield. Slow down when needed, plan your approach, and make sure every action contributes toward completing mission goals.
Tip: Use gadgets, cover, and strategic positioning rather than charging headfirst into enemy swarms. Your medal rate will thank you.
6. Take Advantage of Event Bonuses
Helldivers 2 often includes temporary events that increase medal rewards for specific mission types or challenges. Staying aware of these events is a great way to boost your medal farming sessions. Combining these events with high-efficiency mission runs can yield exponential medal gains in a short period.
Tip: Check the in-game announcements before logging in each day to see if there’s an ongoing medal bonus. Planning around these events can give you a noticeable advantage.
Farming medals in Helldivers 2 doesn’t have to feel like a grind if you use smart strategies. By prioritizing high-reward missions, optimizing your loadout, working with a team, replaying efficient missions, and focusing on objectives over mindless kills, you can maximize your medal output. Following these Proven Methods to Farm Medals in Helldivers 2 has personally made my sessions much more rewarding and far less frustrating.
At the end of the day, the key is consistency and smart play. Stick to the methods that work best for your style, and soon enough, you’ll find yourself swimming in medals, ready to tackle even the toughest challenges Helldivers 2 throws your way.
CrystalViper
