MMOexp:Steps to Obtain the Infuse Weapon in PoE 2
Messaggioda Florencehg63 » 29/10/2025, 7:20
In POE2 Currency, the Huntress class stands out with its dynamic projectile attacks and elemental versatility. Central to her combat prowess is the Infuse Weapon passive skill, a powerful ability exclusively tied to the Amazon Ascension. This article explores everything you need to know about Infuse Weapon—from how to obtain it, to understanding its mechanics and optimizing its use for devastating elemental damage.
How to Obtain Infuse Weapon
The journey to acquiring Infuse Weapon begins with completing one of the Huntress's class-specific trials:the Trial of Sekhmas or the Trial of Chaos. Successfully completing either of these trials unlocks the Amazon Ascension path, granting access to a wide array of unique skills and nodes tailored for the Huntress.
One key node on this path is the Elemental Infusion node, which requires only 2 Ascension Points to unlock. This low cost means players can secure Infuse Weapon early by simply completing the lowest difficulty version of POE 2 Currency the trial. Once unlocked, this node grants the Infuse Weapon passive skill, marking a pivotal enhancement to the Huntress's offensive capabilities.
Infuse Weapon as a Passive Skill
Unlike active skills that require manual activation, Infuse Weapon is a passive skill. This means it operates continuously in the background and triggers automatically when its activation requirements are met. Players do not need to right-click or press any specific buttons to use it.
Another important aspect is that Infuse Weapon does not have an associated skill gem. This exclusivity means only the Huntress class can benefit from this skill, emphasizing its specialized design to complement the Amazon Ascension's unique playstyle.
Florencehg63
