Forza Horizon 6 The Boss Guide: Reach Maximum Promotion Quic
Messaggioda FabledGlimmer » 22/05/2026, 3:07
If you are trying to unlock the “The Boss” achievement in Forza Horizon 6, the main goal is simple: reach maximum promotion level in one Horizon Job. The achievement is worth 30G, but depending on which Job you choose, the grind can either feel quick and easy or unnecessarily long.
After spending time with different Jobs across the Japan map, a lot of players agree that one option stands out as the fastest route: Raku-Raku Food Delivery in Tokyo City.
This guide focuses on the quickest and least frustrating way to finish the promotion grind while keeping the process smooth and consistent.
What Are Horizon Jobs?
Horizon Jobs are side activities spread across the map. Instead of standard races, they work more like story missions or driving services. You usually take on delivery work, transport tasks, or time-based driving challenges with their own progression system.
Each Job has its own promotion rank.To unlock “The Boss”, you only need to max out promotion in a single Job category, not all of them.
That is why choosing the right Job matters.
Why Raku-Raku Food Delivery Is the Best Choice
Among all Horizon Jobs, Raku-Raku Food Delivery is generally considered the easiest for fast progression.
The Job is located around the Tokyo City region, where missions are short, compact, and easy to repeat. Compared to longer countryside routes or mountain driving Jobs, the food delivery missions can be completed quickly once you learn the streets.
The biggest advantage is mission length. Most deliveries only take a few minutes, so even failed attempts do not waste much time.
Another reason players prefer it is consistency. Once you memorize a few shortcut routes, earning 3 stars becomes much easier.
Always Aim for 3 Stars
Promotion XP mainly comes from your star rating.
If you only earn 1 or 2 stars repeatedly, the promotion bar moves very slowly. Getting 3 stars consistently makes a huge difference and cuts down the overall grind.
Because of that, it is usually better to restart a bad run immediately instead of finishing with a lower score.
A clean 3-star route is worth far more than several average attempts.
Ignore the GPS When Necessary
One of the biggest tricks for these missions is understanding that the GPS route is not always optimal.
The navigation system often keeps you locked to the city grid and normal roads, but the fastest route is sometimes much more aggressive.
You can save several seconds by:
Cutting through parks
Driving across small sidewalks
Using narrow alleys
Crossing open plazas
Taking direct lines between streets
Tokyo’s dense layout actually helps once you know where shortcuts are located.
During timed deliveries, shaving even 2–3 seconds off a route can be the difference between 2 stars and 3 stars.
Restart Quickly Instead of Finishing Failed Runs
If you hit heavy traffic, miss a turn, or crash badly early in the mission, restarting immediately is usually faster than finishing the attempt.
The game lets you retry quickly, and using fast restarts saves a surprising amount of real-world grinding time.
You should also skip unnecessary dialogue and transition scenes whenever possible. Over dozens of runs, those skipped seconds add up.
Adjust Your Difficulty Settings
Unlike regular races, Horizon Jobs do not really reward you for making the game harder.
If your goal is simply maximum promotion, lower the difficulty and make the missions easier on yourself.
Recommended Settings
Lower Drivatar difficulty
Keep traction control enabled
Use stability control if needed
Keep braking assists on if you struggle in wet conditions
Use automatic transmission for consistency
Tokyo’s streets can become slippery during rain, especially in tighter corners. Keeping assists enabled helps maintain speed without constant spinning or sliding.
There is no penalty for using easier settings while grinding promotion.
Learn the Traffic Patterns
Traffic is one of the few things that can randomly ruin a good run.
After several attempts, you will start noticing where traffic commonly appears during certain delivery routes. Some intersections consistently become dangerous because AI cars cross at awkward angles.
Once you recognize these spots, you can prepare for them in advance instead of reacting at the last second.
In many cases, slightly lifting off the throttle before a blind intersection is faster than crashing and losing momentum completely.
FabledGlimmer
