If you’re just starting out in MLB The Show 26, the Cornerstone Program is your fastest ticket to building a solid Diamond Dynasty roster. Designed for new players, this program focuses on quick progression, high-impact rewards, and minimal grind. Here’s everything you need to know to get the most out of your Cornerstone packs.
What the Cornerstone Program Offers
The Cornerstone Program is all about efficiency. Completing it gives you high-OVR cards that can immediately strengthen your lineup, plus extra XP, packs, and Stubs to help your team grow.
Main Cornerstone Card: Usually a strong Diamond-level player, perfect for anchoring your squad early. Examples include 87 OVR Travis Hafner or 88 OVR Salvador Perez.
Progression Bonuses: Along the way, you’ll earn up to 5,000 XP per milestone, multiple The Show packs, and Stubs.
Quick Completion: The program can be finished in roughly 20–30 minutes if you focus on the right objectives.
Fastest Way to Complete the Program
Follow these steps to maximize your efficiency:
Prioritize Moments
Moments are short, single-game challenges themed around your Cornerstone player. Completing all Moments first gives a big chunk of your required program points.
Focus on General Missions
Missions like tallying total bases, strikeouts, or other stats can often be completed in any mode. You can knock out multiple missions in a single game by stacking your lineup strategically.
Stack Rewards with Conquest or Mini Seasons
While completing missions, run them alongside Conquest maps or Mini Seasons. This lets you earn extra packs, XP, and Stubs without extra grind time.
Cornerstone Pack Tips for Beginners
Open and Use Immediately: Cornerstone cards are meant to be your core starters. Get them into your lineup quickly to help with tougher offline missions.
Check the Inning Path: Cornerstone choice packs usually appear along the Inning XP reward path. Make sure to track your milestones so you don’t miss any packs.
Consider Evolution Missions: Some Cornerstone cards may have optional Evolution missions to further boost stats or unlock extra rewards. Even though 2026 emphasizes Moments over stat-grinding, it’s worth checking if your card can be upgraded.
For new players, the Cornerstone Program is your shortcut to a strong early lineup. Focus on Moments first, stack missions efficiently, and use your packs immediately. With just 20–30 minutes of smart play, you can secure a high-OVR player and valuable rewards that will carry your team through the first part of the Diamond Dynasty season.
