High-Priority Upgrade Systems
The most effective way to gain power is to focus on gear that doesn’t need frequent replacement and systems that provide permanent stat boosts.
1. The Daevanion Board (U)
This is the core of your character’s strength. Daevanion Points are earned from Regional Quests, Sealed Dungeons, and material conversions. Spend these points wisely:
Orange nodes: Boost your stats directly.
Blue nodes: Improve active skill levels. Leveling skills to 8, 12, or 16 unlocks important secondary effects that can significantly increase your damage output and survivability.
2. Permanent Gear (Belt & Amulet)
Unlike armor, these items stay relevant for a long time and provide stable stats.
Noble Belt: Earn enhancement scrolls from completing Strongholds. You can morph a +10 Noble Belt into higher rarities and eventually reach Gold.
Revelation Amulet: Upgrade using Monolith Feathers (also called Empyrean Traces). A full upgrade to Unique +10 requires roughly 140 feathers.
3. Weapon Enhancement
Prioritize upgrading your weapon above all else. A weapon upgrade provides the most noticeable increase in damage and overall clear speed. Even minor enhancements can make a huge difference in boss fights and dungeon runs.
Efficient Farming & Progression
If your goal is to power up quickly, optimizing your resource gathering is essential. Avoid spending Kinah on temporary gear when it could go toward permanent upgrades.
Extract, Don’t Sell:
Instead of selling unwanted items, extract them to recover Enhancement Stones. Extraction often returns all the stones you used, so your only loss is the Kinah spent on the process. This makes your progression more efficient without wasting resources.
The “Alt” Strategy:
Many competitive players use alternate characters to funnel resources to their main Daeva. For example:
Run the Fire Temple (Explore Mode) on alts. It has a high drop rate for gold items and requires less energy than main runs. These drops can be used to reroll stats on your main character’s end-game equipment.
Sealed Dungeons & Strongholds:
There are around 50–60 Sealed Dungeons and Strongholds in the game. Completing them is essential for unlocking 100% XP progress in certain regions. They also provide crystals needed for the Daevanion Board, making them a core part of long-term gearing.
Community Perspectives on Gearing
Players often debate whether to chase top-tier gear immediately or focus on sustainable, gradual growth. Common advice includes:
“Upgrade your items, even if they’re blue, to at least +10 and extract them later when switching to better equipment.”
“Belts tend to stay relevant for longer, so upgrading them early is safe. For smooth progression, quest accessories are simply the smarter choice.”
The key takeaway: balance your resource investment. Permanent gear upgrades and the Daevanion Board will carry you farther than constantly swapping temporary items.
Fast, Safe Kinah Management
When powering up quickly, Kinah management is critical. Purchasing resources or upgrades from a trusted source can save weeks of grinding. Aion 2 Kinah on U4N is a reliable way to boost your progress without risking your account. U4N is a trusted platform used by competitive players to skip the boring grind and focus on practicing. By using verified sellers, you can safely accelerate upgrades, making sure your Daeva reaches top performance as efficiently as possible.
