First-to-Third Decision Guide in MLB The Show 26
Messaggioda FabledGlimmer » 29/01/2026, 6:46
In MLB The Show 26, making the right decision on whether to send your runner from first to third can be the difference between an inning-ending double play and a crucial scoring opportunity. This decision can seem tricky at times, but with some practice and knowledge of the game mechanics, you can make smarter, more reliable choices. In this guide, we'll break down the factors you should consider when deciding whether to send a runner from first to third, using simple steps and clear explanations based on common player behavior.
When Should You Attempt to Take the Extra Base?
What is the first thing to consider when deciding to go from first to third?
The primary factor in making this decision is the situation on the field. You need to evaluate the current game conditions. Key elements include the speed of your runner, the arm strength and accuracy of the outfielder, and the positioning of the fielders. Here’s a quick breakdown:
Runner's Speed: If you have a fast runner (like someone with a high Speed or Stealing attribute), they’re more likely to successfully make it to third base without getting thrown out.
Outfielder’s Arm: If the ball is hit to an outfielder with a strong arm, such as a player like Aaron Judge or Mookie Betts, you’ll want to think twice. A weak-armed outfielder may give you a better chance.
Base Positioning: If the ball is hit in front of you or towards the outfield corner, the timing of your decision matters more. For example, if the outfielder has to adjust or turn, your runner might have more time to reach third.
Is there any situation where going from first to third is more favorable?
Yes, absolutely. You’re more likely to send your runner to third when there’s only one out. With one out, the risk of being tagged out at third is less critical because you still have a chance to score from another base hit, especially with runners already in scoring position. In contrast, with two outs, getting thrown out at third would end the inning and waste a potential run-scoring opportunity, so you may opt to stay at second base.
How Do You Know If You’re Going to Make It?
What indicators help predict whether the runner will make it safely to third base?
Predicting the success of sending a runner from first to third involves paying attention to the following:
Distance and Timing: If the ball is hit into the outfield and your runner is halfway between first and second, you’ll have a window of time to judge whether to take that extra base. Look at the trajectory of the ball. If it’s a sharp line drive, the runner may not have enough time. However, on a fly ball or slower-hit grounder, your runner will have more time to adjust.
Speed of the Ball: A well-hit ball that travels far into the outfield can give your runner the extra time they need. But if the ball is a weak hit, the outfielder will have more time to get the throw to third.
Pitcher’s Windup and the Fielder’s Positioning: If the fielder is playing deep, you might have a better shot at advancing. Pay attention to how deep or shallow the fielder is positioned as the ball is hit, and use that to gauge how much time your runner has.
How Can You Safely Control the Runner?
What controls help prevent getting thrown out at third base?
In MLB The Show 26, controlling the runner to third is all about timing and using the right buttons. Here are some things to remember:
Base Running Buttons: Use the R2 (or equivalent) button to trigger the decision to send your runner to third. This is often combined with the direction on your analog stick to control the exact timing.
Sliding and Breaking for Third: Use the slide button to break for third. If you're close to the base and you know you won’t make it, use the slide button to minimize the risk of being tagged.
Manual Control vs. Auto Control: Some players prefer manual control over the runner’s decision-making process, whereas others leave it to the AI to make the call based on the situation. If you’re playing on manual, remember that you can stop the runner halfway between second and third to assess the situation more clearly.
Should You Risk It with a Runner on First and No Outs?
Is it ever a good idea to go first to third with no outs?
While it’s a riskier play, there are times when you might want to try this aggressive approach, especially if the outfielders are weak, the pitcher has a slow windup, or the batter has good contact. With no outs, you have the luxury of still having two chances to move the runner into scoring position. However, you’ll need to be extra cautious of the ball's placement and the arm strength of the outfielder.
Typically, if you're down by a few runs and need to create scoring opportunities, the risk of being thrown out at third may be worth the reward. But generally, it's safer to avoid going for third when you have no outs.
What Happens If the Runner Gets Thrown Out at Third?
Is it always the runner’s fault if they get thrown out?
Not always. Sometimes the decision-making process is out of your hands if the fielder’s throw is on target and the runner isn’t fast enough to beat it. However, as a player, you can minimize these mistakes by:
Choosing the Right Moments: Only send your runner from first to third if you’re confident in the timing and the fielding situation.
Paying Attention to the Outfielders: If you see a strong arm, it might be better to hold up the runner at second base.
What’s the best strategy if you get thrown out at third?
Don’t let a failed attempt deter your gameplay. In MLB The Show 26, aggressive base running can lead to more scoring opportunities, but it’s essential to know when to take risks and when to play it safe. If you get thrown out at third, you’ll need to adjust for the next play and learn from it. Always think about your runner's speed, the outfielder's arm, and the count of the batter for the next at-bat.
Final Tips to Make the Best Decision
How can I improve my ability to make these decisions?
The best way to improve your decision-making on the base paths is to practice and develop a sense of timing. Over time, you’ll learn how to read the situation and how your players react to different fielding conditions. Here are some strategies:
Play Situationally: Practice sending runners from first to third during different in-game scenarios, including with one out, no outs, and two outs. The more you do it, the more comfortable you’ll become.
Learn the Players' Attributes: Familiarize yourself with your team’s speed and the outfielders you face. Knowing when to trust your runners (and when to not) will help you make better decisions.
Review Your Results: If you’re not sure why a certain decision failed, take a minute to review the play and assess if you could have made a better choice. Sometimes the most basic decisions can make the biggest impact in a game.
If you're looking for an edge in MLB The Show 26 and need some extra resources to help you on your journey, buy MLB 26 stubs Nintendo Switch to boost your roster and put together a team that’s capable of handling these tough base running decisions with greater efficiency.
FabledGlimmer
