100 Lethal Weapon Kills
Messaggioda coupleslv » 16/01/2026, 19:19
Now the bo7 bot lobby challenge is all about carnage. The Listkeeper has asked you to kill with equipment instead of bullets. You'll be required to kill at least 100 zombies using your equipment (frag-grenades, C4, semtex bombs, monkey bombs, and the best option: Kazmir Devices). Preparing your lethal weaponry is key.
A new stage will begin, and many Ravagers (heavy enemies), may spawn. You don't need to waste ammunition. Instead, you can use the Kazmir Gersh device. One well-placed Black Hole can take in and destroy several dozen zombies simultaneously. Monkey bombs can be used in conjunction with frags. Toss the Monkey into the crowd of zombies. After that, frag or C4 will do it. Use your team to coordinate. You can share equipment, and get Max Ammo after the round.
The team must have 100 kills of equipment. It's cumulative for your team so divide and conquer in coop (but don't go overboard, because advancing too many rounds can make the next step harder). Keep an eye out for the kill counter if you see it in the game. Otherwise, just throw until the trigger is activated. If you play alone, it's possible that you need to use a lot of rounds. Try to group zombies tightly to get the most out of each explosive.
By the time you reach the finish line, the operator on the ground will have confirmed your success. He'll say something like: "That's how to use the tools that you are familiar with." Listkeeper is pleased with your artistic carnage. (Possible rewards: This may be a camo reward or cosmetic. Some reports say this could unlock special camos or at the very least, progress your challenge's camo counts. You can find rewards on screen.
mmoset Tactical Tip: If your crafting supplies are low, you can use the Salvage that is dropped by zombies killed to craft more equipment at a Crafting Table. Instakill powers-ups are also helpful. Even one frag will wipe an enormous wave under Instakill. This counts towards your 100. In co-op you should cover the person deploying gear so they are not hit by grenades. Aether Shroud will allow you to safely plant C4 at the center of a large group.
(At the current stage, take some deep breaths. You've already completed half the challenges. Make sure everyone gets ready, regroups, and replenishes their ammo/equipment. A new set of challenges awaits.
(Event Intelligence - A recon intercept confirms, that by Christmas 2025 a Double XP will be active through the holiday period and most likely up until New Year. Profit from this period - you will get twice as many rewards on every kill. The faster you achieve these objectives, the higher your weapon ranking and the more quickly you will be able to level up weapons. It's an ideal time to farm experience while you hunt for the Infestation.
BO7 Zombies Christmas Guide
Translation: withstand the cold for 5 minutes, without your weaponry. After the unrestrained destruction of all your equipment, the Listkeeper forces you to take part in an endurance challenge. All players must be outside on the frozen areas during the entire 5:00 timer. The twist: the timer is only active when zombies die. If you stop the killing, then literally, the timer freezes.
This is a difficult balance. If you kill too quickly, then you will be overrun by the new spawns. A slow kill train can be a good strategy. "You don’t always need to kill... Get a killing and it takes only 5 seconds," one operative observed. The ideal way to play (solo, or with a co-op team) is to loop the zombies near a heating source. You can slowly drain the clock by killing one zombie per few seconds. Each kill grants approximately 5 second countdown. You can stop killing and the clock will stop. Do not go idle for a long time. Also, don't mowing them down all at once. This could cause you to end the round early and have to deal with a fresh wave.
In co-op only allow one person to kill each turn. The horde will not be wiped out too quickly. It's possible to take turns with teammates: After Player A has a hit, he kites and the timer continues to tick. Once it is close to stopping, Player C gets to have a hit to keep things going. All players have to remain outdoors. If someone retreats to the inside, they could fail (or will at least not be counted for completion) Keep together near a fireplace to avoid getting cold. Here, you can use your weapons normally. The "stripaway power" clue may just be a reference to being out-of-your-comfort zone. Therefore, your Pack a Punched weapons and perks could save your life. Field Upgrades come in handy if things get dicey. Ring of Fire helps thin the herd while Aether Shroud saves you from being trapped. Don't forget to keep enough zombies on the battlefield to keep your timer running.
Survive for 5 full minutes and you will be rewarded with the message, "Challenge accomplished." You've earned respect for your humility. Mutilate Camo Unlocked. With this success, you unlock the Mutilate Camo - a grisly and new camouflage which marks your feats of endurance. You've shown you can battle with patience and calm.
Extra Tips The biggest danger is the cold. The screen will turn icy. Run to a fire barrel to warm you up. If they become too dense, don't hesitate to thin them out. You can always stop the killing process once it is safer. In coop, you can have one person run a loop (of zombies), and another player peel off kills from the line. Rotate your roles if anyone's armor breaks, or if they need to take a break. Working together will make it much easier for you to kite and kill zombies than if you were alone. If you're playing alone, you may want to use a Decoy Bomb or Monkey Bomb. They will hold zombies in place without killing any of them.
Goal 6: Precision is tested - 25 critical kills in a row
Listkeeper 2: Score 25 consecutive critical kills, without missing. 25 consecutive headshots is the goal. Each bullet has to be lethal and hit the target. Body shots or whiffs can reset your count. This is an exercise in skill (or, if you have a good aim assist perk like we do! ).
Setup. If you haven’t yet, immediately buy Deadshot Daiquiri. With this perk, your aim will be snapped to zombie heads. This is perfect for this challenge. As one soldier joked: "They call my goal hacks Deadshot Daiquiri controls spam... it is OP." Equip your weapon with stability - an LMG or assault rifle that has a low amount of recoil is ideal. Or a good tactical rifle. Avoid shotguns or explosives as they can cause your streak to be broken. Turn off Elemental Pop and any explosive ammo modifications. You don't want an accidental Brain Rot or Fireworks effect to steal a kill, breaking your chain. Cryofreeze works fine. It slows zombies while making their heads brittle. This can make it easier to get a headshot.
Execution. Look for a medium size train of zombies. Aim high. Then, start popping off heads one byone. Count up your kills. For solos, a missed head will result in failure. Therefore, go slow. If you are attempting the challenge, your time is unlimited. You can pause and reline up before shooting. This will save you from panicking. If you're playing in co-op with other players, it would be wise to allow one player to handle the challenge while they cover them. This could include weakening some zombies or holding others back. Teammates shouldn't get any kills unless everyone is in need of their own 25 streak. Communication is essential: let your teammate know if you plan to go for the streak. This will prevent them from accidentally killing a zombie. In our recce, one player yelled out "Wisp_T. I will freak if your partner kills a zombie!" - showing the frustration felt if their partner accidentally breaks the'streak. Hold your fire or use the melee option if you absolutely need to, but do not interfere.
Do not lose heart if, midway through the game, you hit a noncritical. As long as your team is not overwhelmed by the zombies, you are allowed to play again in that round. It may be wise to try again in the same round if you failed. If you fail, you should arm yourself before attempting again. You need to absorb any hits as you line up the headshots.
You will be rewarded for a successful 25-headshot streak with the following: "The ice retreats reluctantly... perhaps your bravery isn't only a word." It's not stated here that a camo has been added, but this step is essential to progress. Listkeeper wants to see your precision.
Pro tip: if Insta Kill is dropped, grab it. Any shot you make that connects counts as a kill. Insta-Kill powers up can be held on the map until you’re ready. Then, grab them and pop 25 skulls with ease. ADS (Aim Down Sights) or equipping a telescope will increase Deadshot’s bonus. Click heads slowly and deliberately on PC. It's a risky and time-consuming tactic to kill a zombie, but it works if you shoot it. If you want to be more efficient, it's best to attack in a single flowing stream.
coupleslv
