Arc Raiders Walkthrough: Lay of the Land
Messaggioda coupleslv » 16/01/2026, 19:16
The Spaceport is the first place you need to look for shipping arc raiders items.
A Lay of the Land in Arc Raiders asks players to locate LiDAR scanners in the spaceport. This mission is divided into two sections: locating the shipping notes in order to figure out where the scanners have been shipped, and using the clues in order to locate the scanners. Spaceport, with its long sightlines and wide open spaces, is often one of Arc Raiders’s most difficult maps. Both players and robots can easily spot you. Here are the steps to follow to find your way.
Lay of the Land - A walkthrough guide and arc raiders coins walkthrough
Lay of the Land has three sections on the Spaceport's map. However, you must complete them both in one go and then successfully extract.
Find the Shipping Notices in Jiangsu Warehouse. This is located to the North on the map. When you arrive, head to the 2nd floor of the building on the Northwest corner. This will take you into an office that overlooks the sand warehouse. You should see an option "collect notes".
You can find the scanners at the top floor of Control Tower A6. Enter the east end of the building, with the statue shown above. Then go up behind it. Then, go to the top floor and follow the South Wall until you see a few boxes. Interact with the boxes to get a LiDAR scanner. Add it to your inventory.
At this stage, you will need to successfully use the LiDAR Scanner. However, in Arc Raiders if you do not have a loadout available you can place it in the Safe Pocket.
You may have to sprint across this map in order to complete the mission. Once you reach Control Tower which is a loot-rich area, this will be even more of a problem. If you are worried that players will get violent, read our Arc Raiders guide, which contains helpful advice to prevent being attacked.
Arc Raiders' update 1.3 includes a smattering bugs fixes and some nerfs of the Venator pistol. This weapon was a favorite for destroying Arc Raiders high-level Arc. Some things have not changed: the process of assembling a weapon loadout remains fiddly. And the community still can't decide whether or not the stockpile is the right size.
Smoldering chatter about the state of your stash has been reignited following the update 1.3. It has shaken up strategies used to defeat powerful Arc. Arc Raiders has been designed to be balanced by a cycle consisting of acquiring resources, spending them, and then losing them. The economy would become less stressed, ridiculous loadouts could be made, or players might feel the need to collect everything. However, there is a large gap between the infinite storage and the current tiny space. This gap has sparked some lively debate.
I've been watching the Arc Raiders communities on Discord, Reddit, YouTube, etc., and I feel that the stash discussion can be divided in two different categories: How big the stash is, and how intuitively it works. The first debate has been pretty heated. However, the second is more settled and focuses on the idea that the stash should be more intuitive.
Loadouts created with one click would be much easier to use than the many steps required to create bags, shields, guns, mods, ammo, healing items, throwables, keys, etc., from separate menus and shops. I can't possibly be the only player who uses a free loadout every now and then because they lack the patience necessary to make a complete kit.
There's no one who is against streamlining crafting. Then what about something like "We should have more stash space" or "We should increase the stacking limits of items"? They're some fightin words here in Speranza.
Downtownklownfrown, who has a wonderfully named account, replied to a comment about inventory management. "Even though I can craft items in order to bring them on raids in the future, the value of those items is lower than what I would get from crafting the stacks. I end up losing more space by trying to make items that I will take," he said. Another comment agrees, even though it beats the post's 1.3 rating.
coupleslv
