U4gm discusses How to Get Regal Orbs in Path of Exile 2
Messaggioda Alam560 » 30/09/2025, 9:42
Lots of Path of Exile 2 players want to get Regal Orbs. As an important PoE 2 Currency , Regal Orbs help make gear better. You don't need to look for complicated ways to get them. Mixing them into your daily gameplay is enough, and the key is knowing which gameplay loops drop them more often.
League mechanics are a great choice. Every season, Path of Exile 2 has special league activities. For example, one season might have a "Rift Mechanic"--killing special monsters in rifts and opening rift chests can drop Regal Orbs. The monster drop rate for currency in league mechanics is higher than in normal maps. So during a season, you should spend more time on league content. It's a faster way to get Regal Orbs.
The basic crafting in your hideout can also make Regal Orbs. Once you unlock your hideout, you get a crafting bench. One of the bench's options lets you make Regal Orbs with other Currency. For example, you can use a few Alteration Orbs, a rare item, and a small amount of other materials to make one. This crafting option doesn't need a high level. New players can use it right after they unlock their hideout. It's a steady way to get Regal Orbs when you have extra low-tier Currency.
Map mods affect Regal Orb drops too. Before you run a map, you can add a "Increased Currency Drop Quantity" mod to it. This mod makes all monsters in the map more likely to drop currency--including Regal Orbs. Adding mods uses Map Pins, though. Don't waste your Map Pins on low-difficulty maps. Save them for endgame maps. Those maps already have better drop rates, and the mod will make them even better.
Group play can make farming faster. Farming maps alone is slow. If you play with a group, everyone kills monsters together. You clear maps faster, so you can run more maps in the same time. That means more chances to get Regal Orbs. Group play also lets you share some of the currency drops. Playing with friends not only helps you get more Currency, but also makes the game more fun.
Another small tip is to farm "currency zones". Some areas in the game are marked as "High PoE 2 Currency buy Drop Zones"--like a certain canyon area. The monsters here have a natural higher chance to drop currency. Regal Orbs are more likely to drop here too. You can write down these zones. When you have free time, go farm them a few times. The Regal Orbs will add up over time.
Alam560
